Full Solid CAP and big heat-pipe MB on Intel platform – MSI P35 Platinum first look
  • Full Solid CAP and big heat-pipe MB on Intel platform – MSI P35 Platinum first look
    On Intel chipset product line schedule, they usually renew the whole
    products series from half to one year.
    The 975X chipset exist for a long time, the P965 also launched for almost a
    year.
    The upcoming Intel new generation processor will speed up to FSB1333MHz
    and DDR3 architecture, then the P35 and X38 series chipsets will become the
    new generation leader in second half 2007.
    The board I got this time is P35 chipset based – MSI P35 Platinum – DDR2
    The box design, this time they use different theme on cover, got another
    better style
    Inside packing, the cable color and wording is also enhanced from old design.
    (CD driver not in photo)
    The motherboard itself
    Down left side
    Even P35 have same design with 965P on single PCI-E x16 lane design.
    But higher level boards will make them as dual VGA layout.
    Audio chip use ALC888T, 7.1 channel HD audio with mant solid CAPs.
    Down right side
    5 SATAII and 1 IDE port.
    Red bottom is for Clear CMOS function.
    DRAM part
    4DIMM DDRII
    CPU PWM part use 4 phase design
    IO shield
    Except 1394, also support 2 extra eSATA ports
    This time MSI have the brake through design on heatpipe design compare
    with their old products. They have 4 special parts to high light.
    The first part: up left on CPU socket.
    The inscription with the pipe name “CIRCU-PIPE”, looks good.
    Second part: Up right side on CPU socket.
    Third part: North bridge pipe
    It’s special design that I’ve never seen before. Comes with bigger surface to
    spread the heat, seems better then other normal design.
    Forth part: South bridge.
    The copper and pipe is thick in heatsink.
    The testing modules
    On this coming P35 product, we see MSI comes with enough function and
    better look hestsink with special design,
    The special feature and outlook design is almost align to a higher standard
    with the three big MB manufactors.
    This time MSI coming very fast with well prepared, hope MSI can have more
    brake through on overclock limited, then their P35 series will have good
    reputation on P35 market soon.
    อ่าไรหว่า สุดยอดๆๆ
      chipset ใหม่มาแล้วเหรอเนี้ย
        นึกถึงรถไฟเหาะตีลังกาเลยครับ
          ขอบคุณท่าน windwithme มากๆคับ หาแต่ของน่าชมมาให้ดู
            แม่ เจ้า โว้ย อะไรเนี่ย
            และแล้ว บอร์ดชิปเซต 965P, 975X ก็จะต้องลดราคา แย้
              ง่า...กำลังสงสัยเลยว่าเอามาลงเวบเราหรือยัง บอดสวยน่าใช้มากๆ
              ถ้าจำไม่ผิดรู้สึกท่านนี้เขาจะเป็นคนไต้หวันครับ ถ้าใช้ภาษาเก่งๆก็ขอบคุณเค้าเป็นภาษาอังกฤษน่าจะดีนะครับ
                Heatpipe เยอะๆ ไม่ใช่เรื่องดี ยังไงก็ร้อน
                เป็น Heatsinkตัวโตๆ +พัดลม กับ heatsink ถาคจ่ายไฟแยกต่างหากดีกว่า
                  อลังการงานสร้าง
                  สวยงามจับใจ
                    ไม่ไหวครับ MSI ช่วงนี้สู้ GIGABYTE , ASUS ไม่ได้เลย
                      MSI ก็ไม่ได้เลวร้ายมากนะครับ
                      แต่ยังไงผมก็ใช้ ASUS เหอะๆ เวนจริงๆ
                        อลังการจริง ๆ แต่ก็ใช้ Asus อยู่เหมือนกาน
                          Nice
                            ต้องลองเอามาลองดูว่ามันจะแน่สักเท่าไร
                              5000 บาท ยังไงก็ซื้อ ฝันเอาอะ
